2 different circuits sharing a ground?
Old 04-03-11, 03:01 PM
I'm wiring a bathroom exhaust fan that came as a combo light/fan. I was initially going to have separate fan and light fixtures. The way the wiring played out was that the fan was going to be on the bathroom circuit and the light on another. With this combo unit I can still wire the fan and light on separate circuits as initially planned "IF" the ground can be shared. Is that ok and within current NEC? The wiring will be inspected a couple weeks.
Thanks
Mark
Old 04-03-11, 03:08 PM
CasualJoe's Avatar
Upvotes Received: 16
Thanks
Mark
Sure, the ground wire can be shared. It sounds as if you'll be using a 3 wire cable to wire the combination unit, such as 12-3 or 14-3 romex. That one grounding conductor in the cable can be used to ground both the fan and light.
Old 04-03-11, 04:17 PM
thanks.
I'm actually using 14-2 & 12-2 which is already in place, if I switched to 3 wire cable it will just cause more work/$ for me. This will also not be a multi branch circuit as I will be using 2 separate breakers, a 20A bathroom circuit running the fan and a 15A 'other/lights' circuit running the light. Since the fan and light are in the same metal box (literally) I will have to share a ground between them, which I can do I think but just want to make sure.
But I cannot and will not share a neutral.
Old 04-03-11, 05:08 PM
pcboss's Avatar
Upvotes Received: 6
It would be much easier to add the fan to the circuit with the lighting. Why are you trying to use 2 circuits?
The fan/light junction boxes are very small so the less wires or cables the easier it will be.
Old 04-03-11, 05:38 PM
I agree but wiring is in place based on previous idea.
The reason I'm using 2 circuits is because I initially was going to have a light fixture and then a few feet away have the exhaust fan and have already ran the wiring. I came across a combo light/fan unit that looks good and serves both functions. The fan was going to be on the 20a bathroom circuit due to where the switch was going to be and location of wiring made it easy. The light, same thing, ease of where the switches are and location of wiring.
I have ran wire to the fixture with 14/2 from the light switch (power supply, single pole and only room for a 1 switch box due to stud location) and ran wire to the other switch for the fan control about 5 ft away near the vanity.
I want the fan to be able to run while the light is off, will that happen with only using 14/2?? If the light switch is off will there still be power to the unit that will allow the fan to be controlled from another switch?
I don't want to go out and buy more/differnt wire and rerun it if I don't have to.
Old 04-03-11, 06:24 PM
As previously stated, you are going to have a VERY hard time trying to terminate 2 seperate cables in that fan/light junction box. Its usually very difficult to terminate a single 12/3 or 14/3 cable. i would run a new 14/3 or 12/3 and use a switch over switch at the location where it will be switched from.
