Ground rod depth
Old 04-08-11, 04:11 PM
jjrbus's Avatar
Received 1 Vote on 1 Post
Ground rod depth
Replacing Zinsco 100A panel with GE 100A panel. So far I have gleaned that I will need to install 2 8 foot ground rods at least 6 ft apart to pass inspection.
What I do not see is a depth or height for the rods. Do the top of the rods, wire and connectors need to be exposed or buried 6 inches, 1 foot ?????? I'm in Florida if that makes a difference. JIm
Old 04-08-11, 04:18 PM
Justin Smith's Avatar
The entire rod must be underground.
Old 04-08-11, 04:36 PM
Tolyn Ironhand's Avatar
Received 59 Votes on 52 Posts
Ground rods are to be pounded into the ground their entire length so just the top is exposed. This can be straight down, up to a 45 degree angle or buried into a trench 30" deep.
Old 04-08-11, 07:32 PM
Received 29 Votes on 28 Posts
My understanding is that the whole rod (clamp and all) needs to be underground. Dig a small hole - 6" or so deep and pound in the rod. Leave the hole open for the inspection then cover it up.
Also, don't forget to put the acorn clamp on the rod before you start pounding. It'll be difficult to get on after the top is mushroomed.
Old 04-08-11, 08:19 PM
Mine, nor any of the poco's are shroomed.
Old 04-08-11, 08:38 PM
jjrbus's Avatar
OK, how do you get one in without shrooming it?? JIm
Old 04-09-11, 08:22 AM
Soft ground. Sometimes it helps to pre-wet the ground hours before to pound it in.
Old 04-09-11, 09:32 AM
jjrbus's Avatar
I live in SW Florida, there is no solid ground here, it is a swamp covered with a layer of sand. The sand is just barely think enough to support a house. I belive a ground rod pushed into the ground a foot or so would sink on its own given enough time. JIm
