Electrical Box is flush with the stud
I have an electrical box in the basement but its mounted flush with the stud. Should the box be move so its flush with the drywall or can a bigger hole be cut in the drywall and longer screws used to attach the outlet to the electrical box?
If you can easily move the box so it will be flush with the drywall, I would do it. Otherwise, you can use a box extender and longer screws to mount the device. Code requires boxes to be no more than 1/8" set back from the face of the drywall and the box extender satisfies this requirement.
