Ice Block Cutter
Old 04-10-11, 10:27 PM
Ice Block Cutter
I just made an ice block cutter to make ice cubes using #22 AWG Ni60 and it seems to work, but I am skeptical if it will last for long because what I did was I simply connected the two terminals of our 220V home power source to the two ends of my wire to heat up and cut the ice blocks. There are no other electrical components installed for possible regulations of current and/or to save electric bills.
Could you please help me with a better design.
Old 04-11-11, 03:34 AM
Received 29 Votes on 25 Posts
What you have done is create a really good way to get killed.
A live bare wire and working in water. Not the best plan.
Old 04-11-11, 10:32 AM
Received 42 Votes on 40 Posts
Nichrome ice cutters must be driven from a low voltage power supply! Yours is a major hazard that could easily kill a person.
Old 04-11-11, 10:49 AM
Received 53 Votes on 50 Posts
Better design than this?
Hammer and chisel
Old 04-11-11, 06:15 PM
Justin Smith's Avatar
Maybe something like this will work better than your widowmaker.
12V 6A Power Supply
Old 04-11-11, 06:53 PM
Tolyn Ironhand's Avatar
Received 59 Votes on 52 Posts
Hammer and chisel
How about a chain saw??????
Old 04-11-11, 06:58 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Bandsaw pluged into a GFCI if ice is to be edible. Lubricating oil on a chain saw would contaminate the ice. Bandsaws for meat wouldn't.
Old 04-11-11, 07:06 PM
Bandsaw pluged into a GFCI?
An isolation xfrmr may also help just a tad.
Old 04-11-11, 08:20 PM
You use vegetable oil when cutting ice. There is also many manual saws out there.
