MC cable cutter
Old 04-13-11, 07:45 PM
Received 1 Vote on 1 Post
MC cable cutter
I need to cut 3/8" MC cable conduits (without the wires in them).
I bought a cutting tool from HD, I thought it would cut the conduit across, but it turns out it cuts the conduit "longitudinally".
Am I missing something? Why would it cut it lengthwise? Or did I get the wrong tool?
Since I am going to feed my own wires, may be it's better I cut it with an angle grinder?
Old 04-13-11, 08:14 PM
Justin Smith's Avatar
For flex, I use a sawzall. MC cable, I use diaganal cutters.
Old 04-13-11, 08:21 PM
CasualJoe's Avatar
Received 26 Votes on 20 Posts
MC cable has wires installed in it at the factory. What you probably bought is for MC cable like this
Amazon.com: Seatek RF170 1-1/2" roto split: Home Improvement
It sounds as if you are just cutting flexible metal conduit. I think you'll find you can bend it, snapping the spiral, and then snip it with diagonal cutters.
Old 04-13-11, 10:04 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
You can also cut it part way with a hacksaw then snap it.
Old 04-14-11, 07:18 AM
Tolyn Ironhand's Avatar
Received 59 Votes on 52 Posts
This is the method we use for all spiral wrapped cable/conduit. (AC/MC/Flexible conduit)
Old 04-14-11, 10:10 AM
Received 42 Votes on 40 Posts
You cut through one rib of the spiral then you can pull it apart into two pieces with an "unscrew" motion.
Old 04-14-11, 05:54 PM
Those old wiring books seem to be more informing than new ones.
Old 04-14-11, 06:00 PM
ray2047's Avatar
Not always. One I have warns it is best to use a fuse box because breakers are not approved for use in many municipalities. Perhaps the best wiring book is the one Sears use to sell.
Old 04-14-11, 07:05 PM
There are still alot of long lost tricks in them. I do like fuses personally, but that is for another time.
