20 amp, 240v sub panel for garage?
Old 04-15-11, 01:12 PM
Hi,
I have a 20 amp 240 volt feed from my main panel to my garage. The circuit is protected at the main panel with a 20 amp, 240v double breaker. The wire going to the garage is 12-3 with ground. If I connect this feed in my garage to a sub panel in my garage that accepts multiple breakers can I add more than 2?
What I want to have in the garage is a sub panel with one 15amp 240v breaker dedicated for an a/c unit (max draw 1100 watts at 240v), one 15amp 120v breaker for lights, and one 20amp 120v breaker for outlets.
My max load is expected to be 1100 watts for a/c + 600 watts for lights + 900 watts for outlets.
If a double 240v 20amp breaker can support 3840 watts I would think this would work?
Any thoughts from someone with knowledge appreciated
Old 04-15-11, 01:16 PM
Received 42 Votes on 40 Posts
The subpanel is unnessecary when you have a 20A multiwire circuit. Just put the AC on one leg of the MWC and the general-purpose loads on the other leg of the MWC.
Old 04-15-11, 01:25 PM
But the a/c needs 240 volts, so it would need both legs, so thats why I am thinking I need the subpanel so I can have 240 and 120 breakers available in the garage. Just not sure if its ok to add 2 more 120 volt breakers, one on each leg?
Old 04-15-11, 01:28 PM
Oh I see. It would be okay to put a 6-20R (240V, 20A) receptacle on the 20A multi-wire circuit to power the air conditioner. You just use the two hots and the ground (black, red, bare) and not the white. Note this should be before your GFCI receptacles.
You could do the subpanel if you want to, but it is an unnecessary cost.
Old 04-15-11, 01:50 PM
I think the mini split a/c unit I plan to put in needs the neutral and the ground being it will be hard wired. I don't mind putting in the little sub panel in the garage, just was not sure if it would be acceptable to add the 3 separate breakers in it? Sounds like it is as long as I keep the neutrals and the grounds separated and add ground rods?
Old 04-15-11, 02:07 PM
Yes that sounds fine to me.
