running wire to the second floor
Old 05-08-11, 05:13 PM
i have a older home. it has ballon framing. when i go to the second floor. can i remove the base borad and go around the room that way? the base borad is a 1 by 6 .
is there any thing about the height of the run around the to outlets and switches. i know they should be certain height.
Old 05-08-11, 05:48 PM
CasualJoe's Avatar
Yes, you can. It's common in older homes to see Wiremold surface raceways and boxes mounted on the baseboards.
Old 05-08-11, 06:58 PM
Justin Smith's Avatar
If the wire is less than 1.25'' from the edge of the stud you need a 1/16'' steel plate to block a nail or such. Also, watch you do not hit a firebreak as those can be a pita to get around and you will have to either get a snake bit or cut a hole in the wall to drill through it and then fill around the wire with fire caulk.
Old 05-08-11, 09:47 PM
Tolyn Ironhand's Avatar
The only height requirement is they must be less that 6' off the floor. (yes, that is 6 feet. as in 72")
