generator panel question???
Old 05-11-11, 07:34 PM
Cool generator panel question???
i have all the correct equipment i just have a question about if it is ok to tie all of your neutrals and grounds together or if you are supposed to have seperate neutral and ground bars (if so i would have to add one..) or do i just tie them all together on the one bar that came in the generator panel. i just dont know if there would be a neutral backfeed into the main panel or if that makes any difference? thank you..
Old 05-11-11, 08:09 PM
Justin Smith's Avatar
Grounds and neutrals only get tied in the main panel. They need to be seperate after the main, and the neutral must be insulated from the panel.
