12VDC fan to 110v outlet
Old 05-18-11, 11:31 AM
I have two SL-FD 14025 140mm cooling fans that have a 4-pin power supply / 3pin mother board connection. The fans are 12VDC with a power rating oof 0.96W and current of 0.08A
I would like to convert the power supply so that the fans can operate from a standard 110V outlet. What do I need to do to cinvert the power supply? Can I simply splice a 12v converter to the fan?
Old 05-18-11, 11:38 AM
Gunguy45's Avatar
Super Moderator
Received 2 Votes on 2 Posts
Yes...a "wall wart" 12VDC power supply of 300w would be just fine.
Old 05-18-11, 12:10 PM
These fans have three wires, a red, yellow and black. The wall wart has two wires. Which do I splice and what do I do with the third wire?
Old 05-18-11, 12:24 PM
Gunguy45's Avatar
Super Moderator
Ahh...didn't read well enough I guess. Not sure I can answer..but I'd guess that the yellow is for speed sensing...
Looking at the pic from Newegg...the P/S connector just uses the red and black....so that must be the actual power connections. Red would be + and black would be -. You'll probably need a meter to determine which wire on the wall wart is what...
Old 05-18-11, 12:40 PM
Thanks, whet would happen if the wiring were backwords?
Old 05-18-11, 01:06 PM
Gunguy45's Avatar
Super Moderator
It will run backwards....thats all.
Old 05-18-11, 01:54 PM
Justin Smith's Avatar
Some of those fans have diodes in them so they do not run if wired backwards.
Old 05-18-11, 03:57 PM
Will anything other than 300w work such as 1.2A? Not sure where to find the adaptor?
Old 05-18-11, 05:01 PM
Gunguy45's Avatar
Super Moderator
Shouldn't matter. It will only supply what the fans draw...just make sure it is DC not AC. Many computer shops and even thrift stores have bins full of wall warts for really cheap.
Old 05-19-11, 11:05 PM
Received 1 Vote on 1 Post
A power supply that would work with two fans like you posted would have to supply at least 160MA @ 12VDC so any supply greater then 160MA should work as long as it is a quality regulated supply. A 300Watt supply is overkill and probably would be to expensive for just two fans
Anyway in your case the RPM lead is the yellow wire and just to power the fan will be left unconnected and insulated with tape or a wire nut
If you use a wall wort type supply with two black wires (One with a white stripe) the wire with the white stripe is usually the positive wire but you should test to be sure before you connect everything
Old 05-20-11, 06:13 AM
Gunguy45's Avatar
Super Moderator
Jeez...I meant milliwatt...lol. I just picked 300 out of the air...cause there's one plugged in right in front of me probably.
