pool pump hums and doesn't rotate then trips house breaker. wiring?
My pump worked fine last summer. I did have my entire breaker box replaced this past winter. Now when I flip the pump switch, there is humming and then shortly after the breaker in house trips. Is it possible that it is not wired right at the breaker box and I just need to swap the wires?
Adding to what the others have said have, you used the pump since the new breaker box was installed? If so definitely mechanical. In fact if this was a wagering site I'd put my money on mechanical. I just asked about voltage to eliminate it.
