Does a 3-way dimmer work in a multi-location setup?
Old 05-28-11, 08:45 AM
D
I have hallway lighting with 3 light switches. I want to install a dimmer at one location of the three switches. The identified location for the dimmer has an existing 3-way switch. Can I use a 3-way dimmer in its place? (I got a Lutron Q-603PH)
Old 05-28-11, 09:39 AM
L
Cool Does a 3-way dimmer work in a multi-location setup?
Hello destruct05
Yes you can use your new dimmer to replace one of your 3 way switches.
Make sure you mark the wire that's on the Dark Screw of the old 3 way switch
This will be your Common Wire..
Hope this helps ---
Let us know how you made out with your wiring project
Have A Nice Day
Linesman
Old 05-28-11, 12:26 PM
D
Thanks Linesman. Worked out fine.
