Outdoor Temporary Service To Camper
Old 06-02-11, 04:24 PM
63zerb's Avatar
My In Laws are coming from AZ to stay with us in PA. They will be in a camper in our yard for two months. The total run from panel box to camper is about 115 feet. I am not sure but I think the plug on camper is 30 amp (see pics) Is the correct wire size 10-2 for 30 amp? Should this be protected by GFCI breaker? Can some one explain label on camper (see pic) It says about the connection for 110 125 volt A/C Do not connect to higher voltage. (Hope pics work not sure if URL business is correct.)
Old 06-02-11, 04:38 PM
chandler's Avatar
Use this to post pix on your post> http://www.doityourself.com/forum/el...your-post.html
Old 06-02-11, 05:37 PM
pcboss's Avatar
Are you planning on installing a small RV receptacle on a post or using a cord?
Old 06-02-11, 07:02 PM
ray2047's Avatar
It wasn't. Must be in jpg, gif or png format for embedding.
Old 06-04-11, 04:30 AM
63zerb's Avatar
Plug would be installed on a post concreted in with embedded 3/4 conduit to two gang outdoor box.
Old 06-04-11, 04:43 AM
63zerb's Avatar
pics
can anyone open these?
Last edited by GregH; 06-04-11 at 06:34 AM. Reason: Edit url for pics to show in post
Old 06-04-11, 05:06 AM
Pics
Nope. Use Chandler's instructions posted above.
Old 06-04-11, 05:20 AM
Tolyn Ironhand's Avatar
If you run PVC conduit, you will have to bury it 18" down and run 3 #10 THHN/THWN wires (Hot/Neutral/Ground). The conduit run will have to be continuous to run the THHN. Most cases it is helpful to run Romex from the panel to a box on the outside of the house and then convert it to the individual conductors. I also suggest using stranded wire.
OR you could run 10/2 w/G UF cable the entire way. That will be required to be buried 24" The cable will be required to be protected on each end with conduit.
Old 06-04-11, 05:26 AM
30 Amp RV Receptacle
Here is a good write-up on the subject:
RV Electric
Click on the 30 amp link on the left.
Hope this helps.
Old 06-04-11, 07:11 AM
Justin Smith's Avatar
You could use an 100' 30A extension cord if it is only temporary.(90 days or less) IIRC, travel trailers already have a 20'cord. Just install a tt-30 somewhere on your house. You will need to portect your cord connections, too.
