electrical problem
Old 06-04-11, 09:15 AM
electrical problem
I have a bathroom and laundry room that are not getting any power. I have checked the outlets and switches and they are all good. I am not sure how to check the light fixtures. The breaker did not blow. Any suggestions?
Old 06-04-11, 10:02 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
How did you check receptacles and switches?
http://www.doityourself.com/forum/el...ml#post1837048
Old 06-04-11, 12:36 PM
Multimeter. I got an electrician to come out and I had a couple of grounds in my main box that needed to be replaced. He fixed them and solved my problem. It only cost me 55 dollars and it only took him about 45 min.
Old 06-04-11, 12:44 PM
ray2047's Avatar
Glad you got it.
Grounds are not required for the receptacles to work. It must have been something else. Maybe a loose neutral.
Old 06-04-11, 01:06 PM
Gunguy45's Avatar
Super Moderator
Received 2 Votes on 2 Posts
Or the electrician did a bit of tightening after he reset the GFCI. $55 for almost 1 hr? Never saw that before.
Glad it's fixed...but with a little more time/info...you probably would have been able to fix it yourself.
Old 06-04-11, 03:09 PM
Justin Smith's Avatar
What should've it cost?
Old 06-04-11, 05:58 PM
Received 33 Votes on 25 Posts
In my area an electrician (not a handyman) wouldn't even start his vehicle for less than $125.
Old 06-04-11, 08:16 PM
Quite a bit more than that!
Old 06-05-11, 07:53 AM
CasualJoe's Avatar
Received 43 Votes on 35 Posts
Being a Saturday, it could have been time and a half or even double time in some areas. Furd's number is about right.
Old 06-06-11, 10:45 AM
Received 42 Votes on 40 Posts
Unless it was at my neighbor's house (the good ones, not the loud ones) and I could have walked over there in my slippers it would have been a lot more than that. Sounds like the OP got a great deal.
