Garage and Outdoor Outlets
Old 06-07-11, 01:10 PM
Hoping ya'll don't mind two questions (today >>lol):
1) I put the outlets which are outdoors on the same breaker as outlets in the interior of the garage?
2) Can I put more than 6 outlets on the same breaker?
thanks,
Old 06-07-11, 01:18 PM
Received 42 Votes on 40 Posts
As long as they are for general-purpose use, yes. All should have GFCI protection.
Again, for general-purpose use, yes. The NEC code in the US has no upper limit on number of receptacles per circuit (Canada does for you northern readers). To power specific appliances or built-ins you may need separate circuits. For misc lighting and hand tools it is no problem.
Old 06-07-11, 09:32 PM
Also pay attetion to the conductor size as well due most of the genral circuits typically either #14 or #12 Awg size so keep it the same.
And also for outdoor receptale you have to use the in use receptale cover this is very specfic in the NEC code { Canada is simuiar to this } ( few case we call them bubble cover as well so you know that is the in use cover )
Merci,
Marc
Old 06-08-11, 02:09 PM
Justin Smith's Avatar
To add to that, the receptacles also need to be listed weather-resistant.
Old 06-08-11, 08:54 PM
Received 27 Votes on 26 Posts
Justin, is the weather-resistant receptacles a new NEC requirement? I didn't realize they were needed outside.
Old 06-09-11, 08:26 AM
The 2008 code first mandated it.
Old 06-09-11, 06:58 PM
It is on 2008 NEC code requirement only if your state did adopt the 2008 NEC code requirment { not all states are on 2008 NEC some are still on 2005 or earlier edition }
Merci,
Marc
