Electric motor amps
Old 06-16-11, 04:47 PM
Electric motor amps
I have an electric fan in a roof ventilator. The motor has gone bad. The manufacturer is no longer in business. I have found a replacement motor from another manufacturer that is the correct size. everything appears the exact same except the amps.
The original motor was 3.4 amps, the replacement I have found is 3.1 amps. Is this a problem?? Thanks
Old 06-16-11, 05:41 PM
Tolyn Ironhand's Avatar
Received 73 Votes on 65 Posts
It draws less amps so it is no problem what so ever.
Welcome to the forums!
Old 06-19-11, 09:42 PM
Most case useally not a issue as long you have the same frame size, mounting etc etc are the same you are fine with it. { just make sure you have CW or CCW rotation motour some are wired in that way }
Merci,
Marc
