GFI reset
I have lost power on a breaker that has not tripped. I am suspect of a GFI somewhere. On out door lighting is there a reset hidden in a lighting assembly somewhere?
Received 0 Votes
I have power at the breaker. I have reset all the breakers several times. I have lost power on 2 circuits. When looking for a reset on a CFI. I am not missing a big red button marked reset, Am I? I was thinking this rester lies inside some housing.
Steved, you should find a GFCI outlet in places normal to regular outlets. Look for a GFCI type receptacle in any outside outlets, garage, bathroom, basement,or even in the kitchen. At one time or another, codes allowed one to run from a GFCI outlet located somewhere (say in the kitchen) and then run to an outside plug. Nowdays, kitchens have to be on by them selves, which is true of bathrooms also, but you could still have a GFCI outlet in the garage and feed to an outside outlet.
There should be no GFCI reset button hidden inside of a fixture, but if you have a 2nd panel somewhere in your home, there might be a GFCI type breaker in it.
Good luck. Rick Miell
