Code question
Old 06-30-11, 07:37 AM
T
Code question
Hopefully and easy one...
Can I use wire like the one linked below in a fixed outdoor application if its above ground and completely sealed inside liquid tight conduit? It basically looks like extension cord but it's less than a third of the price of NMWU.
WIRE SJTW 16/3 75 M CANADA WIRE - Rona.ca
Old 06-30-11, 08:34 AM
ray2047's Avatar
What are you trying to wire? What size breaker?
Old 06-30-11, 08:54 AM
T
Its to wire from a minisplit ductless Heat pump outside to a head inside. The manufacturer spec calls for 16/3 with ground.
Old 06-30-11, 08:58 AM
T
The NMWU in 14/3 w ground at HD is 5.99 a meter (3 feet) and I can't seem to find it in 16 which isn't surprising as its kind of a specialty application. If it's up to code to use the other wire linked above I'll go that route but if not I'll just cough up and use the 14/3 nmwu.
EDIT: I'm in BC , Canada
Old 06-30-11, 09:16 AM
I
Received 45 Upvotes on 43 Posts
Code requires the #14. Smaller sizes are not allowed except for very specific circumstances.
Old 06-30-11, 09:19 AM
T
The manufacturer spec'd 16 and it is UL certified so code is 16.
Old 06-30-11, 11:36 AM
T
Thanks for the help everyone. I figured it out.
I actually needed Multi-Pair Shielded Power Limited Remote Control Signal Cable (UL)
Old 06-30-11, 12:23 PM
ray2047's Avatar
You didn't tell us it was for the thermostat. That makes a big difference in the reply.
