Moving a light box to code
Old 07-08-11, 08:43 PM
The way I understand the electrical code, wires connected by wire nuts must not be exposed, but must be in a box. Furthermore, a box cannot be hidden behind drywall - it must be accessible.
So let's say for example someone wants to "move" a ceiling light box, and the box moves farther away from the wire source and needs more wire. We have 2 options.
1) put a cover over the old box and run a new wire from the old box to the new box
2) if a visible cover is not acceptable, we have to run a new wire all the way from the light switch to the new box.
No other way, right?
Old 07-09-11, 04:12 AM
chandler's Avatar
Received 9 Votes on 8 Posts
Right...............................................
Old 07-09-11, 05:22 AM
Tolyn Ironhand's Avatar
Received 595 Votes on 511 Posts
There is possably two more ways.
"accessible" does not me you can access it from the room. If there is an accessible attic above the space you are working you can mount a box up there and make your splice.
Or, if there happens to be another light fixture box between the one you want to move and the switch you could put the old switch leg in there and extend it from that point. Just be sure the box is big enough.
Old 07-09-11, 06:55 AM
Yeah, those are good ideas I'll keep in mind. I forgot to mention that there is no attic access - second floor above.
Old 07-11-11, 09:48 AM
I
Received 45 Votes on 43 Posts
If you're just moving the light a little bit you might be able to use an "apprentice plate". Basically a decorative ring mounted to the ceiling to cover up a hole that was too big. Usually it's made to look like old fashioned plaster work.
