Refrigirator Outlet/20 amp circut
Old 07-14-11, 06:11 AM
Why does my frig keep tripping my 20 am circuit? Background: I have a outlet wired with 20 amp wire (yellow), with a refrig plug in, also coming off that outlet is a yellow wire powering 6 canned lights. Circuit was tripping alot so through trouble shooting I have kept the lights off and the circuit still trips with just refrig plugged in.
Any advice would be greatly appreciated,
Joan
Old 07-14-11, 06:30 AM
Received 98 Votes on 86 Posts
Can you run an extension cord to another receptacle to see if the problem occurs there as well?
Could be a worn out breaker, could be something else.
Old 07-17-11, 05:59 AM
Follow up
Could a lose wire in my canned lights be causing it to trip? I have replaced the oulet with a new oulet, Frig and lights worked great for about 2 hours, than the circuit triped again. Turned off the lights, the circuit has not trip yet, frig contuinues to work, been about 18 hours now.
Old 07-17-11, 06:47 AM
CasualJoe's Avatar
Received 105 Votes on 93 Posts
I'd check the load on the circuit at the panel next. It's possible there is something else on this circuit too that you are unaware of that is causing your problem.
