How to wire a pilot light switch??????
Old 07-14-11, 08:07 AM
Exclamation How to wire a pilot light switch??????
Hi,
I'm replacing a vintage pilot light switch w/a new Decora 5628-2T > Rocker Switch > Commercial Grade > Decora Devices > All Products from Leviton Electrical and Electronic Products 5628-2W and cannot figure out the wiring. I thought I followed the diagram, but all I get is a pilot light that's lit and never shuts off and no switching.
The old switch had two screw pairs. The hot came in and was switched and the neutral passed through. The new switch has only three screws. I checked continuity and there is no switching ever. The black is always connected to the lower right screw and the upper right screw is never connected, no matter what switch position.
I thought this would be a simple replacement, but I need your help!!!
Old 07-14-11, 08:51 AM
ray2047's Avatar
Is one screw silver and two screws brass on the new switch? Colors and number of wires in the box. Were 3 wires entering the box and one pigtailed to two wires?
Old 07-14-11, 09:14 AM
New switch: one black screw, one silver screw, one brass screw (and a ground).
Box: two 14-2 cables (black,white,ground) one line in and the other to fixtures
Old switch: two brass screws, two silver screws
Old 07-14-11, 09:20 AM
ray2047's Avatar
Try pig tailing the two white wires to the silver, the black wire of the power in cable to the black screw and the black wire of power out cable to the brass screw.
I'm guessing a bit on the fact a dark colored screw usually means common. If that doesn't work swap the black wires.
Old 07-14-11, 03:16 PM
PERFECT! Thank you Ray.
Old 07-14-11, 06:47 PM
Justin Smith's Avatar
Did the old switch have an incandescent lamp?
Old 07-14-11, 07:42 PM
ray2047's Avatar
Doesn't matter since the new switch uses a neutral.
Old 07-14-11, 08:11 PM
I was just curious. Ive seen incandescent ones before and just curious if this was the incandescent, too.
