Adding switch to dusk to dawn light
Received 0 Votes
I have a dusk to dawn light. It's has a plug in on the end that is plugged into a receptacle. Right now I can't turn the dusk to dawn light on or off, it just comes on and dusk and turns off at dawn. The receptacle is in a hard place to get at outside the house. Am I able to take the wire of the dusk to dawn light and add a switch to that and then continue it to the receptacle so it is plugged in. Then If I want to turn off the dusk to dawn light for an reason why I am on my deck for a bit I can just turn the switch off and it cuts the power?
Did the light come pre-wired with a cord set and photocell? You may be able to use a line switch. If this is jerry rigged I'd recommend a permanent install and getting rid of the cord set
Received 0 Votes
It did have a photocell, with just the positive and negative wires. I had to add the wire to the light and then run it to my house to the receptacle. I'm not the most knowledgeable when it comes to this stuff so a permanent install might be out of my realm. I could though put the switch in if it works.
To control the light from a single location you would use a single pole switch. You would only connect the incomong and outgoing power and a ground to the switch. The white would stay unbroken.
