Adding A Switch ForA Wall Outlet
Old 07-24-11, 11:05 AM
I am remodeling a duplex that was built in the early fifties. I have taken the drywall off an exterior wall to add insulation, and would like to add a switch for the wall outlet while I am at it.
There is currently one switch for the light that is right outside the door. The electric cable feeds down into the box (presumable from the light). Then it goes down to the outlet, which is the end of the circuit. The cable feeding into the box has a black, white, and red wire. The cable leaving the box for the outlet has only a white and black wire. I am replacing the oulet with a GFCI so that it has a ground.
How can I install an outlet switch in this situation?
Help, please.
Pat:
Old 07-24-11, 11:55 AM
pcboss's Avatar
First, a GFI does not provide a ground.
Secondly we need to know if you wiring is grounded. Ungrounded circuits should not be extended.
Old 07-24-11, 01:18 PM
Grounds were connected to the metal junction box.
Old 07-24-11, 02:04 PM
Justin Smith's Avatar
Is there a ground wire coming in the cable from the breaker panel?
Old 07-25-11, 05:32 AM
No. Guess that outlet just wont have a switch. Don't know what I was thinking. Sorry to bother you all.
