2 Pole Breaker Swap
Old 07-31-11, 08:59 PM
Gen
Gen is offline
2 Pole Breaker Swap
Hello,
Lightning tripped the well pump 2 pole breaker in the house. After I reset it, still no pump power. I measured 120v between each breaker pole (screw) and neutral bus. Then I measured 240v between the poles (screws). So why doesn't pump work--all seems normal. Changing the breaker solved the problem. My question is why was the old breaker not serving properly?? Thanks in advance
Old 07-31-11, 09:16 PM
Justin Smith's Avatar
The breaker may have not closed the circut completely.
Old 08-01-11, 06:16 AM
Gen
Gen is offline
"The breaker may have not closed the circut completely. "
Interesting........does this happen often? Has anyone else seen this problem?
Old 08-01-11, 09:53 AM
I've heard about it, but I have never seen it in person, but I'm not an electrician, either.
Old 08-01-11, 06:58 PM
CasualJoe's Avatar
Received 43 Votes on 35 Posts
At this point it's just speculation and doesn't matter. I suspect the contacts in the breaker may have been burnt and couldn't maintain the full voltage under the load of the pump when switched on, but that's just a guess. Basically, you had a "Bad Breaker". What's more important is you fixed the problem.
