Wiring a attic Fan.
Old 08-06-11, 09:42 AM
Wiring a attic Fan.
Hello,
I my attic, I have a receptacle with two sockets. On one, my AC Coil is connected.
Can i connect the attic Fan on the second socket. It has 3.4 A rating.
Appreciate your help.
Thanks,
gurupuru.
Old 08-06-11, 09:52 AM
ray2047's Avatar
You should be able to if it is a grounded circuit..
Old 08-06-11, 10:06 AM
Justin Smith's Avatar
Is the fan plug-in or hardwired? If it is made to be hardwired, you must hardwire it.
Old 08-06-11, 10:13 AM
Thanks for the response.
I am not sure about it, but it doesnt have a plug connected to it.
It has wires hanging off the thermostat.
Providing a link for the fan here.
Amazon.com: Lomanco 2000 MILL Power Roof Ventilator: Home Improvement
Old 08-06-11, 10:42 AM
pcboss's Avatar
Is the coil 120 or 240 volts?
Old 08-06-11, 11:27 AM
Assuming everything is 120V, you can Just run some 12/2(If a 20A circut) or 14-2(if a 15A circut) from the outlet box to the fan thermostat box.
Old 08-07-11, 05:28 PM
Thank You all.
I hooked it up, as you guys suggested. Got a 14/3 cable ,ran it to the thermostat and plugged into the spare socket on the receptacle.
