Isolation Problem
Old 08-06-11, 04:08 PM
Question Isolation Problem
I have 2 fans, 2 switches, 1 light and one power source. I want to be able to turn the fans on with one switch, the light with the other switch but I'm thinking that you can't isolate the fans from the light when there's only one power source, correct?
thanks
Syb
Old 08-06-11, 05:33 PM
pcboss's Avatar
You could split the power to feed both switches and run a switched hot to the fan and the light. Done all the time.
Are you dealing with existing wiring or new construction? If old we would need to know how many conductors and how the cables are run.
Old 08-06-11, 08:40 PM
Thanks.
Using existing wiring, 2 conductor.
The power is at an outside wall junction box.
Fans are mounted under a balcony and cables run to the junction box
The fan switch is inside the house and cable run to the junction box
Light is mounted under the balcony between the fans and a cable run to the junction box
The light switch is inside the house in the same electrical box as the fan switch and a cable run to the outside junction box as well
Thanks for you help
Old 08-06-11, 09:45 PM
Justin Smith's Avatar
Is the outside wiring cable or conduit? This sounds easy.
Old 08-07-11, 04:51 AM
It's all 12-2 electrical wire cable
Old 08-07-11, 09:41 AM
You should be able to take out the old wire then and replace it with 12/3 UF. Is this all exposed in the outside portion?
Old 08-07-11, 10:10 AM
I think what I'm wanting to do is like what the originator of this thread stated:
Two Lights - Two Switches - One CCT - Electrical - DIY Chatroom - DIY Home Improvement Forum
The only difference is that there is one more load (fan) fed by one of the switches.
Is the schematic provided by Surrogate what you are suggesting I do?
Old 08-07-11, 10:33 AM
Yes, it's exposed but the wire going into the house takes a 90 deg turn inside a wall and would be a real PITA to replace.
Old 08-08-11, 07:21 PM
Figured it out. Problem was I had one wire connected wrong. Thanks
Old 08-08-11, 07:31 PM
ok. Glad you told us.
