Reload this Page >
Outlet causes breaker to trip when something is plugged into it.
Old 08-10-11, 03:51 PM
Every time I try to use this one outlet it trips the breaker I can't seem to figure out why. When I reset the breaker as long as nothing is plugged into that outlet it will reset fine but the ground fault indicator light comes on for a second. Please help
Old 08-10-11, 04:07 PM
pcboss's Avatar
Received 39 Votes on 34 Posts
Are you tripping the breaker or the GFI? What are you plugging into the GFI? How long ago did this start?
Old 08-10-11, 04:37 PM
It is a combination breaker and the receptacle is standard. We just moved in so I am not sure how long it has been going on for.
Old 08-10-11, 05:57 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Are you plugging in the same thing each time?
Old 08-10-11, 06:00 PM
Tolyn Ironhand's Avatar
Received 73 Votes on 65 Posts
Originally Posted by yama450yfz View Post
It is a combination breaker .
When you say it is a combination breaker, what do you mean? Is it an GFCI, AFCI, standard two pole or tandem breaker? Maybe a picture would help.
