Converter for Receptacle of Air-Conditioner to regular three prog plug?
H:
A receptacle of old Air-conditioner has three prong plug which is two parallel slots at the top and one bottom/regular slot. The receptacle of Heater has three prongs plug which is two vertical slots and one bottom slot.
The difference between is two parallel slots of Air-conditioner and two Vertical slots of Heater at the top.
ImageShack® - Online Photo and Video Hosting
My question is :
Is there a plug that enable to convert the receptacle/progs of air-conditioner to regular three progs plug?
Thanks for your help in advance.
My question is :
Received 0 Votes
No, there is no plug-in converter to do that.
The A/C receptacle is 240v/15A, and there is no neutral present, just two hots and a ground. It is possible to convert the outlet to 120v, but it requires actually changing the receptacle to a standard one and moving a wire inside your breaker panel.
If you are lucky, there is a three conductor (black/red/white) cable running to that outlet, and there is a white capped off there that you could use without having to open the breaker panel, but that is extremely unlikely.
Is the heater 120v?
Is the receptacle on a 2 pole 240v breaker?
What is the amperage rating of the breaker?
What color wires are in the receptacle?
