Dishwasher electrical
Old 08-19-11, 06:06 PM
N
Hi, i'm buying a dishwasher for a house that never had one. There is no dedicated circuit for it, and id prefer to use an existing one. There is wiring directly below the spot i need it that simply has 2 basement lights on them (that dont get used often). Is it ok to run those up through the floor for the dishwasher?
Old 08-19-11, 06:09 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Why don't you want to run a new line.
Old 08-19-11, 06:23 PM
N
The breaker box is on the other side of the house, and the basement is finished. I suppose i could call an electrician to take a look, just wondered if i could get away with doing it myself
Old 08-19-11, 09:45 PM
SD515's Avatar
What do the instructions say about the power source? Does it state to have a dedicated circuit?
Old 08-20-11, 04:30 AM
N
nothing about a dedicated circuit, just a 15 or 20 amp that is not on the same ones as the countertop outlets.
Old 08-20-11, 06:23 PM
pcboss's Avatar
Received 62 Votes on 54 Posts
Most will probably call for a dedicated circuit.
Old 08-20-11, 07:02 PM
Justin Smith's Avatar
If it uses more than 50% of the circut's capacity, it needs a dedicated.
Old 08-21-11, 02:12 PM
T
Received 25 Votes on 24 Posts
Many dishwashers use a 1kw heater, so the nameplate rates at near 9 amps. Check yours. If you have a 20A/12AWG circuit going to the lights, you may share. If the existing light circuit is fed by 14 AWG, consider dedicating that circuit to the DW and find another general purpose circuit to power the two basement lights.
Old 08-22-11, 09:24 AM
I
Received 42 Votes on 40 Posts
It wouldn't be the end of the world to use the basement light circuit, but a dedicated would be best. The lights will flicker while the dishwasher is running which is a cosmetic thing that may get annoying.
