Reload this Page >
replace dead wall outlet: both back and side wires inside with back wires stuck
Old 08-23-11, 05:47 AM
Y
the old outlet sent off sparks leaving black burnt mark & died.
the inside wiring has both side (screws) & back (inserted) wires.
2 black wires inserted + one black wire screwed on
2 white wires inserted + 1 white screwed on the side
questions:
is this common to have both side & back wired?
the 4 inserted back wires don't come out upon yanking on it
and there isn't much slack wire left to just cut it.
please advise, thanks
Old 08-23-11, 06:40 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
#1 is this common to have both side & back wired?
More often then it should be in a perfect world. The best way is to connect the three wires to a pigtail and the pigtail to a screw. Backstabs as you know may be less reliable.
please advise,
There should be a release slot next to the hole. A paper clip or very small screwdriver may work. Since you are going to pigtail cutting the wire as last resort should still leave enough wire.
Old 08-23-11, 06:45 AM
Received 94 Votes on 83 Posts
Welcome to the forums
I'd cut as close to the receptacle as you can (if you have to cut) and the pigtail the wires so you have only one black and one white going to the receptacle when you're done.
While what you have is not to my knowledge a code violation, it seems sloppy to me.
Whoops - Ray was faster than me
Old 08-23-11, 11:25 AM
Justin Smith's Avatar
There are also back-wired recepatcles which use pressureplates and you can put 4 wires in the receptacle.
Old 08-23-11, 03:52 PM
Y
i will combine all 3 white wires into 1 pigtail & tie to the side screw where existing white wire is located.
i will combine all 3 black wires into 1 pigtail & tie to the side screw where existing black wire is located.
thanks
Old 08-23-11, 03:54 PM
ray2047's Avatar
Yes, that is correct. White to silver, black to brass.
