Dimmer for LEDs?
Dimmer for LEDs?
I have a set of LEDs that I bought from Ace Hardware. They are for mounting outside.
What I'd like to do is mount these on my deck and then run an extension cord to a plug attached to a switch. My question is: can I buy a dimmer wall switch to operate the LEDs? Will LEDs work OK when attached to that type of switch or can then not be dimmed at all?
Thanks
Thanks
LED I have run into are dimmable with standard dimmers. Here is some good info from Lutron: http://www.lutron.com/Education-Trai...LsandLEDs.aspx
