Dimmer switch problem
I am having a problem with two lights both using a dimmer switch. I suppose a dimmer could be bad right out of the box but I wondering about the wiring.
I have a 12/2 wg romex wire run from breaker to junction box. There I use it for a power source for two seperate lights and want a dimmer switch on each. If all common wires are combined in junction box and the power wire is split to each light, is that a problem? One of the switches will not work.
I am not trying to make a 3-way application. I am trying to control each light alone with a dimmer. What am I missing?
Swap the working and non-working switch to see if it's a bad switch.
Make sure you're using regular incandescent lamps, as CFL and other fluorescents will not work with dimmers.
