CS6364, CS6364C, CS6364N ... What's the difference?
Old 09-14-11, 09:13 PM
crabjoe's Avatar
I'm getting closer to my backup power and need some clarification on the different twistlock ends for 50amp service.
I thought there was only 1 type, which was CS63634, but I'm seeing some ends listed as CS6364C and CS6364N. Can some one tell me what the difference is between the three? Is one more water resistant then the other or are all 3 the same, but different companies just happen to use C, N or just use the standard CS6364?
Thanks!
Old 09-14-11, 09:53 PM
Received 32 Votes on 24 Posts
I'm not saying this is universally true but generally the C suffix means a connector body (female that "connects to the male inlet fitting) and the N suffix denotes nylon construction. Not all manufacturers use this convention but more often than not it is the case.
So the CS6364P would be a male plug, the CS6364C would be the female connector and the CS6364N could be either plug or connector made of nylon.
