400 csed
Old 09-22-11, 06:24 AM
400 csed
Upgrading from 200 to 400amp.
will have existing 200amp and add new 200amp and new 125amp.
Going to have a meter mains type from SquareD, specifically the CU12L400CB with "Class 120 Manual Bypass" or the CU12L400CN with no Bypass.
Have a permit. Do I want or require a bypass?
Also, are lugs to the meter typically supplied by the utility or the homeowner? Its an option with SquareD
Thanks for any enlightenment.
Old 09-22-11, 06:39 AM
pcboss's Avatar
You will need to get the list of acceptable meter equipment from your power company. This should also tell you whether you need the bypass also.
Old 09-22-11, 05:16 PM
CasualJoe's Avatar
Typically, the proper lugs are supplied by the homeowner's contractor.
