new outside light
Old 09-23-11, 11:57 PM
new outside light
I was going to wire up a motion light outside corner of house but deciuded to go with a regular yard light can i use service from the deck light receptable for current to the 75 watt light. Thanks for your help
Old 09-24-11, 05:46 AM
chandler's Avatar
Received 2 Votes on 2 Posts
How do you plan on running the cable? It must be protected, and cannot be exposed to the elements. Does your deck light have a receptacle incorporated into it? I have not seen one. If your existing light has full power and a neutral you can obtain power from there. If it is totally controlled by a switch loop, then your yard light would likewise be controlled by the same switch.
