1800s house (renting) has NO GROUND upstairs.
Hey first post! Help!
1- No ground - Tested with cheap plug light up thing (open ground its says). Also, when plugging up surge protectors - no 2nd light.
2- Voltage (from mutimeter as well) says 119 volts....WTF?
I am renting and have complained. Nothing done yet. Anything in the basement I can do? I have looked (as told) for a seperate ground box. THANKS!
No ground
As a renter you can't do much. Really don't see anything to worry about.
It would be nice to have grounded receptacles, but there's really no solution other than to run new circuits - which as a renter, you're not going to be able to do.
I'd still use surge protectors, but realize that they won't be as effective without a ground.
One of the downsides of living in a historic house.
The only thing that can be done is to run new circuts for grounded outlets.
Another option is th install GFCI receptacles, which will give you 3-prong receptacles. The downside of this is your surge protectors will not provide surge protection.
Since you're renting, ony a liscenced electrician can perform the work.
Since the electric is what would be expected for a house that age and you have cited no major unsafe conditions if I was the landlord I would suggest you look for a house you were more comfortable in. Perhaps if you have a lease he will let you out of it with no penalty.
