460v vs 480v
Old 10-02-11, 04:33 PM
460v vs 480v
i was advised that i need to change my 480v supply to 460v because my motors are rated at 460v,understanding that there is a + -10% .i need to know if this is somthing i should do??? and what would happen if i do this???
Old 10-02-11, 04:59 PM
CasualJoe's Avatar
Who told you that?
IMO, no.
Once you figure out how to do it, post back and let us know. The problem I think you'll find is the power company most likely furnishes you a 277/480 3 phase 4 wire service. To change it to 460, you'd need a transformer. I doubt you'll find one. 460 and 480 volt systems are basically the same thing.
By the way, working with 480 volts systems and circuits is NOT A DIY PROJECT!! If you need anything done to your system, hire a professional who has the proper safety equipment. Serious injuries and/or death can result from tinkering with 480 volts.
Old 10-02-11, 05:05 PM
Tolyn Ironhand's Avatar
480 volt is the same as 460. It is nominal voltage. Unless they are very sensitive to a specific voltage, and the manufacture requires the input voltage to be 460, they will be fine. As you mentioned +/- 10%.
A buck/boost transformer would do the job, but my opinion is the same as yours Joe, it is not necessary.
Informational note: Back in the day, voltage was listed as 110, 220, 460. Now it is listed as 120,208, 240 480.
Old 10-02-11, 10:51 PM
I will add the comment on 460 volts it is the same as modern 480 volts and many electrique motour manufacters do rated them in 460 volts due they allready comperised with voltage drop in there.
Now the other matter it will do come up with this where are you working on this one ? in the commercal place if so that have to be done by electrican to do this there is too many things can go wrong and there is not much leeway with 480 system.
I am used to 415 volts system in France and basically almost the same sistuation as 480 volts not much differnce there as well. again not much leeway with it if not pay attetion to it.
Merci,
Marc
Old 10-05-11, 09:59 PM
I work as an electrician helper, my job was to research what would be the outcome be if i were to run my motors at rated voltage.i'm currently going to school to become an electrcian, and my school book says the motor operates most efficiently at rated voltage.is this correct?
Old 10-06-11, 06:12 PM
Isn't 415 volts (in countries not using 120 volts) from a 3 phase 240 volt phase to common system where only appliances rated for 415 volts or 240/415 volts (or 240 volts only) may be connected?
Old 10-07-11, 06:30 AM
pcboss's Avatar
Tell us why you think this would be true or not. We will gladly help you learn, but I have done enough homework when I was in school.
