Floor heat
Old 10-18-11, 07:31 AM
Floor heat
I need to supply power to radiant electric floor heat wires in a master bathroom.
The floor heater is 110/120v, 1080 watts, controlled (switched) by a wall thermostat.
The branch circuit supplying the bathroom is a dedicated 15a with GFCI breaker in the panel.
Other bathroom accessories (including an 1875 watt hair dryer) may be used in this bathroom so I don't think I should extend the bath circuit to include the floor heat.
Questions:
1.Can I extend an adjacent bedroom circuit to pick up the floor heat, changing the bedroom outlet to a GFI and putting the floor heat on the load side?
2.Do I need to get rid of arc fault devices if present in the bedroom?
Thanks!
Note - providing a dedicated circuit for the heat is by far the least practical solution.
Old 10-18-11, 09:29 AM
That solution is the only legal one.
Old 10-19-11, 11:05 AM
pcboss's Avatar
I agree with Ben. Installing a new circuit is the correct way to go.
