Maximum wattage for a circuit or switch
Old 10-24-11, 04:54 PM
I understand in the case where I have a single circuit supporting multiple sets of lights, the threshold is more on the individual switch's wattage rating and not the circuit itself?
For example, let's say I have a single 20A circuit split into three separate switches, and each controls a group of six to eight recessed lights, I need to make sure the total lights for one group is less than the maximum wattage for that switch right?
So if I have one group of eight lights at 60W each, the total wattage is 480W and I should have a switch for say 600W to be safe, right?
Or do I add up all the wattages for all the switches and the total needs to be less than a certain amount for the circuit?
What I found is that there seem to be no MAX WATTAGE labels on most switches. Today I looked at some of them on the box, and the instruction sheets inside, and on the actual switch carefully, I did not see ANY sort of MAX WATT specifications.
For example, this one by Trademaster
Here is the specification PDF:
http://www.smarthome.com/manuals/4232.pdf
No info is listed. I checked a few Leviton switches at Home Depot, same problem. I must be missing something?
Old 10-24-11, 05:08 PM
CasualJoe's Avatar
Single pole and three way switches are rated in amps, dimming control switches are rated as to the maximum wattage they can be used for.
Old 10-24-11, 05:58 PM
Thanks, how would I figure out if I am overloading my circuit or switches?
For example, if my 20A circuit is supporting three sets of lights:
7 lights at 40W each
2 lights of 100W each
2 lights of 40W each
Three switches, but two of them are in a combo switch. The switches are just standard 15AMP single pole switches.
Old 10-25-11, 03:52 AM
pcboss's Avatar
Your 15 amp rated switches are fine. Even the 2x100 switch is switching less than 2 amps.
Old 10-25-11, 05:18 AM
Volts x amps = watts, therefore amps = watts/volts. Thus, in your case, the first switch controls:
(7 x 40 w)/120v = 2.33 amps
The other two are less than this.
