Replacing a smoke detector with 4 wires to one with three
Old 10-28-11, 10:13 AM
I am replacing a very old smoke detector on a house over 30 yrs old. The old detector has a white, black, violet, & brown wire. White goes to a connector with two whites, black goes to a connector with two black wires.
The violet goes to another white wire and the brown goes to another black wire. The new smoke detector has a white, black, & red. The directions say the red is used to connect all detectors on a single circuit so when one goes off they all do.
Any idea what the violet & brown wires are used for in the house? Can I hook up the white & black wires in the new detector and just cover the additional white & black wires the violet & brown wires go to? I do not have a problem if the detectors are not on the same circuit but it would be great if they are.
Thanks,
Botrott
Old 10-28-11, 11:30 AM
Do you have a security system and the smoke detectors are tied into that?
Or do you have other smoke detectors and if one goes off, they all go off at the same time?
Old 10-28-11, 04:54 PM
There is no security system, there are 2 smoke detectors and I'm not sure if they are connected.
