3 way switches for 3 lights - wiring diagram
Old 10-28-11, 11:36 AM
Hello all. I've got a project installing three outdoor security lights controlled by two 3-way switches. I picked up a lot of good advice from various posts - enough to put together a wiring diagram. Now, before I put this plan into action, I'd like your critique on it. What do you think?
http://img832.imageshack.us/img832/9...sto3lights.jpg
Thanks everyone.
Old 10-28-11, 12:52 PM
ray2047's Avatar
It would work but it is over complicated in my opinion. If you can run 14/3 directly between the two switches the you only need one 14/2 to the lights and between them not two 14-2 cables.
Drawing suggestion: In the future don't include the grounds.
Old 10-28-11, 02:51 PM
Noted. I will consider your suggestion on running 14/3 directly between the two switches. Thank you for the input, Ray.
Old 10-28-11, 08:54 PM
Tolyn Ironhand's Avatar
IF you do stick with your plan, the white traveler is required to be re-identified with black tape as a hot wire.
