Reload this Page >
Relocatable Power Taps (Power Strips) and circuit breakers
Old 11-01-11, 06:12 PM
CircuitBreaker's Avatar
I had a Relocatable Power Tap (A Power Strip) with a broken outlet so I took it apart for the cord and switch (I plan to build a built in one in the new desk I am building)Anyway I though these things were Supposed to have an integral circuit breaker. The one I took apart had a switch marked "OFF" and "RESET" so I assumed the circuit breaker was part of the switch but when I looked at the switch it looks like an ordinary "ON-Off" lighted switch or am I missing something? And were circuit breakers ever required to be in a power strip?
Here is the switch
Thanks
Old 11-01-11, 07:37 PM
pcboss's Avatar
Some of your answers might be in the UL White Book. I left mine in the truck.
Old 11-01-11, 08:32 PM
That is a combination switch, indicator light and circuit breaker.
Old 11-01-11, 11:17 PM
RE: Switch
Thanks Furd I did look up the Switch and it is indeed an all in one device
Now if I can only figure out how to strip SJO cord of the jacket without nicking the 3 inside wires
Thanks all
Old 11-02-11, 04:32 AM
pcboss's Avatar
Ring the outer jacket with a sharp utility knife. Pull the jacket off.
Old 11-02-11, 05:44 PM
Tolyn Ironhand's Avatar
I score the outer jacket and then cut parallel with the cable to the end. Pulling on the jacket will tear it off.
Old 11-02-11, 08:39 PM
Justin Smith's Avatar
And I use a combination of both methods.
