1950 fixture with original wiring, one bulb not working
Old 11-10-11, 01:14 PM
T
Since we are on a roll lately.... My older neighbor lady has an issue with her light fixture and does not have the funds to hire an electrician. My hubby and I told her we would come take a look at it. Here is my concern.
Her house was built in 1950 and EVERYTHING is original (actually really cool appliances). Anyway The ceiling light is adjustable (you can pull on it to bring it closer to the table) and has three standard bulbs in it. One of the bulbs is not working, the other two are working normally.
My guess is the socket has finally conked out but my concern is how easy is it to wire something into a fixture that old? Can I use today's standard sockets?
Old 11-10-11, 01:26 PM
Received 1,198 Upvotes on 1,153 Posts
There are three sockets in there all of the same age. My thought process is that if one has failed, the other two are likely to fail soon as well (they have the same number of hours on them) and I would therefore replace all of them by replacing the fixture itself.
Old 11-10-11, 01:34 PM
T
The problem is she does not want the fixture replaced, its like something out of the Jetsens and she would like to keep it if at all possible.
Old 11-10-11, 02:41 PM
W
Received 60 Upvotes on 52 Posts
Light Fixture
Move the non-working bulb to a different socket to verify whether the problem is the bulb or the socket. Make sure the contacts on the bottom of the bulb are not corroded.
Old 11-10-11, 02:50 PM
ray2047's Avatar
And make sure the tab is pulled up.
Old 11-11-11, 11:12 AM
I
Received 45 Upvotes on 43 Posts
Lighting stores usually sell parts to build-your-own or repair lamps -- cords, switches, bulb holders, etc. I bet you can find what you need at a place like that.
