100 amp service to new garage
Old 11-13-11, 03:14 AM
D
Hi I am building new garage and need 100 amp service. I have 200 amp service to my house and from my breaker box to where the new one will go is about 190 feet what size wire and what about voltage drop. I doubt I will ever use 100 amp but it depends on what kind of heat I put in the garage. Thanks so much for any help
David Keith
Old 11-13-11, 07:21 AM
W
#3 copper or #1 aluminum if using conduit and THWN.
# 2 copper or #1/0 aluminum if using USE direct burial.
You will need 4 wires.
2 ground rods with #8 or #6 copper ( I prefer #6 so you do not have to protect it).
Separate the grounds and neutrals.
Panel or disconnect needs to be service rated.
Old 11-13-11, 10:24 AM
B
FYI - Here is a voltage drop calculator...
electrician2.com voltage drop calculator
Old 11-13-11, 02:55 PM
D
OK thank you very much so I need 2 seperate grounds?
Old 11-13-11, 04:16 PM
CasualJoe's Avatar
Received 84 Votes on 74 Posts
I believe code requires the resistance to the earth ground, through the ground rod, to be 25 ohms or less. In lieu of proving this to the inspector, the code allows you to install two ground rods 6 feet apart.
Old 11-13-11, 04:39 PM
B
Also that is considered a "subpanel".
Grounds are on a separate bar (optional purchase and you should be able to get one with the screws for your specific panel - holes predrilled in panel.).
Then remove the "neutral bonding screw" in the new subpanel.
Old 11-14-11, 12:44 AM
D
OK thanks so much for the information
