Rewiring a Variable Speed AC motor
Old 11-13-11, 09:11 AM
I have a Toro 12 Amp AC Variable speed blower motor that suddenly guit working.
The motor shows continuity and is not burned. Can I re-wire directly from the power source and by-pass the variable speed controls with a simple On/Off switch?
Thanks.
Old 11-13-11, 10:45 AM
Tolyn Ironhand's Avatar
Received 43 Votes on 37 Posts
Is this for a Toro leaf blower? Because I just had one stuck to on and will not shut off yesterday.
Short answer would be yes. Bypassing the speed control should work just fine.
Old 11-14-11, 09:10 AM
Received 42 Votes on 40 Posts
If it's just a universal motor with two leads, then yes you can bypass the variable speed controller and just wire to hot and neutral.
