Tnengr: Timer Questions
Old 11-13-11, 06:52 PM
I have a another question about P&S RT1 timer. I am looking for a countdown timer switch that I can install in two locations in a Master Bath to control the same fan. The fan is Fantech that draws from two locations. Ideally I would like to install the timers in a parallel mode. Not as a three way switch. Can I use two RT1 timers in parallel. If not is there another timer switch that would work?
Old 11-13-11, 07:58 PM
Yes but the timers *must* use the same breaker and circuit!
If you used another breaker, there would be a chance you would be creating a 240 volt short. And probably fry both timers.
