cable question
Old 11-16-11, 01:07 PM
Bernard_01's Avatar
cable question
greetings from NH once again.
I will be installing a 240V single section of electric baseboard heat. The cable feeding this heater is NM 12-2 with ground. The breaker is a 20A DP breaker. The neutral conductor has been painted with a black marker as a hot conductor. Am I good to wire this heater?
thanks.
Old 11-16-11, 01:39 PM
You're good to go with the heater.
Old 11-16-11, 05:53 PM
thanks.
Does your thermostat break both wires in a full off position?
