How to Add Light Fixture to Wall Cabinet Exterior
Old 11-16-11, 08:44 PM
I have a small bath that I'm remodeling and trying to come up with a creative way to use a particular light fixture. My initial plan was to mount them in the normal way above the vanity on the wall behind the vanity. But one fixture would be especially close to the corner wall. So, my brainstorm is to mount that side ON the side wall and then to build a custom, very narrow cabinet unit that would hang on the other side of the vanity from the wall behind the vanity. It would be a very unique design and functional to attach the light fixture for this side to the side of this cabinet. Question is how to do that in code-compliant way?
Currently, there are code-legal, inspected and passed boxes (for fixtures) in the wall behind the vanity. If I essentially hung the cabinet over the top of one of them I would guess I can't just snake the wire out of the wall into the cabinet to hook up the light fixture. But I've seen something similar in a high-end hotel with the bed unit. So how do they do it? Basically, the bed unit had two wall-hung bedside table units, each with a sconce light attached directly to the wood. In their case I think I remember looking and seeing that they were simply plugged into an outlet.
But is there a legal way to actually mount a fixture-type box inside the cabinet itself? I want to do this in a code-legal way.
Thanks for any insight.
Old 11-16-11, 09:40 PM
ray2047's Avatar
A box does not have to be burred in a wall to be legal however if the cables are not protected you may need to use AC rather then NM-b.
Old 11-17-11, 07:25 AM
So I could just come out of the in-wall box with a short length of AC cable into the cabinet mounted box and be legal, correct?
I didn't stop to think about this simple solution mainly because, while I'm familiar with AC, I've not used it, so it simply wasn't on my radar.
Very simple solution, though. Thanks for pointing out the obvious.
Old 11-17-11, 09:37 AM
ray2047's Avatar
Yes, you can use Armored Cable (AC).
