kleinhuis connector ??
Old 11-18-11, 04:48 PM
sgull's Avatar
Anyone know whether/how these kind of wire connectors can open or release so the wires inserted into them can just be pulled out, and then reconnected afterward re-using the connector again? They are a Kleinhuis brand connector.
http://i207.photobucket.com/albums/b...nectors002.jpg
http://i207.photobucket.com/albums/b...nectors001.jpg
Is there some trick to it or or these things just not made to un-connect and have to be cut off? thanks
Old 11-18-11, 08:59 PM
Tolyn Ironhand's Avatar
They are similar to the Ideal push in connectors. You can get the wire out by twisting back and forth on the connector while pulling on the wire.
I believe the manufacture does not recommend reusing the connector.
Old 11-22-11, 01:17 PM
sgull's Avatar
I am having no luck at all trying to twist the things back and forth. They are hard little blocks and don't seem to even begin to "twist". Are you sure there's not some other way to get these things off?
Old 11-22-11, 01:35 PM
pcboss's Avatar
Looks like they can be pried open. Look at the slot just above the orange wire.
Old 11-22-11, 01:45 PM
sgull's Avatar
I tried that. Couldn't do it. I gave up and just cut the blasted things off. thanks
