bath fan light - ceiling @ 45degreeangle, not flat
Old 11-19-11, 10:39 AM
Do I need to be concerned that the fan bearings will burn out if the ceiling isn't parallel to the floor? If so, are there any low somes (reasonably priced) fans that anyone can recommend? Thx!
Old 11-19-11, 10:47 AM
Gunguy45's Avatar
Super Moderator
Received 2 Votes on 2 Posts
I wouldn't worry about it. As much as they are run, wear isn't that big an issue. Cleaning the accumulated dust on the blades and in the housing every year will do much to keep it running.
Old 11-19-11, 11:18 AM
CasualJoe's Avatar
Received 43 Votes on 35 Posts
Check out Panasonic bath exhaust fans.
Panasonic Vent Fans ? Whisper Quiet & Energy Efficient Ventilation Systems
Old 11-19-11, 02:28 PM
Tolyn Ironhand's Avatar
Received 73 Votes on 65 Posts
You get what you pay for in a fan. Get the most expensive you can afford (Within reason). A $20 fan will sound like a $20 fan.
Old 11-19-11, 03:48 PM
Sounds good, thanks for the tip.
