Help
Old 11-20-11, 08:42 AM
Help
I am trying to wire a construction heater into the 50 amp plug at an RV campground. The connections are NEMA 14-50R on the outlet and I want to plug in a heater with NEMA 6-15P can this be done safely?
Old 11-20-11, 08:56 AM
pcboss's Avatar
Received 114 Votes on 99 Posts
You cannot use a 15 amp device on a 50 amp circuit.
Old 11-20-11, 09:13 AM
Gunguy45's Avatar
Super Moderator
Received 4 Votes on 4 Posts
Hey pcboss...just for my edification...why not? Isn't it like plugging a 1A lamp into a 15A outlet?
Couldn't you just wire the plug to only use the 2 hots and ground?
Different rules for high amp 240V? Or is it because you aren't using the neutral somehow?
Old 11-20-11, 09:21 AM
oops
So I messed up it is actually a 14-50R to a 6-30P. Is there a safe way to do this? If not please explain why?
Old 11-20-11, 09:46 AM
B
As to why not 50 amps...
What would appear as a short circuit to a 15 amp breaker might appear as a normal load on a 50 amp breaker!
So instead of a 50 amp breaker tripping in the event of a short circuit with a 15 amp device, it might "think" that short circuit was a "heating element" and continue to supply power to it! Then you have some very hot wires heating up and then causing a fire.
The following goes into how you would calculate how much "resistance" a heating element would have for example. A "short" would have an amount of resistance. Actually just a long run of wire has resistance...
How Much Resistance Should a Hot Water Heater Element Have? | eHow.com
Old 11-20-11, 10:08 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
Mount a 30a fused disconnect and a 6-30 receptacle to a board. Output of disconnect goes to the receptacle. Connect fused disconnect and receptacle box with a nipple.
Run #6 3-conductor SOW from the input of the 30a fused disconnect to a 14-50 plug. Assuming this is a 240v heater no wire is connected to the neutral of the 14-50 plug.
Old 11-20-11, 10:14 AM
Gunguy45's Avatar
Super Moderator
Ahhh I see now, guess I just wasn't thinking of the protection aspect...thanks Bill.
Old 11-20-11, 10:32 AM
B
Yes. And at some point you could take an 18 gauge extension cord say 100 ft. long and short the ends together. And that would appear as a normal load to a certain high amperage breaker. Too early for me to figure that out - what amperage... 100 amp breaker? 200 amp breaker?
Anyway here is resistance per foot of various size wires...
Resistance of Wire (Wire Resistance Calculator)
Then also as a wire heats up, the resistance increases.
